Up Topic American Welding Society Services / Technical Standards & Publications / AWS D1.6 Figture 4.9 nomogram for bend radius
- - By Toey TNDT (**) Date 09-19-2015 04:16
Dear All ,
Please clarify about Nomogram
Supposed that Base metal is SS 304 Elongation 40% and Electrode is E308-15 Elongation 30% Thickness Specimen  10 mm.
1. Which  Elongation is requrired Base metal  SS 304 or Electrode E308-15 for select draw line ?
2. When Elongation is 30% bend radius would be 9.5 mm. ?
3  When Elongation is 30% bend radius would be 19.5 mm. ?
Regards ,
Toey TNDT
Parent - - By Dmccullock Date 09-25-2016 21:44
Have you got a reply to this question. I was also curious about this.
Thanks
Parent - - By 803056 (*****) Date 09-26-2016 00:59
I don't have a copy of D1.6 with me, but if I recollect one would use a bend diameter of 4 times the thickness of the coupon as you would with carbon steel.
Parent - - By Dmccullock Date 09-26-2016 12:47
The picture above is  directly from D1.6. I was just curios what number you would use for elongation. Would this number be elongation of base metal??
Thanks
Parent - By 803056 (*****) Date 09-26-2016 13:21
Use the lower ductility value.
Quick question; how are they calculating the ductility, reduction of cross section or elongation? The values are not the same.
