Up Topic Welding Industry / General Welding Discussion / learning CAD
- - By kcd616 (***) Date 09-22-2015 01:43
Al,
tell how bad this is for my first try
taking a CAD class and auto CAD has me beat for now
but used weld CAD for this and so much easier
sincerely,
Kent
Attachment: kent1-1.jpg (33k)
Parent - - By 803056 (*****) Date 09-22-2015 01:57
Above my pay grade.
Parent - By kcd616 (***) Date 09-22-2015 02:01 Edited 09-22-2015 02:25
Al,
fixed my mistake
wrong file name
DAMN IT Al!!!! I am welder not a computer geek:twisted::wink::evil::eek:
"Dr. McCoy aka Bones on star trek"
look now
thank you
sincerely,
Kent
Parent - - By aevald (*****) Date 09-22-2015 02:31
That's pretty dog gone awesome Kent. I haven't graduated to a CAD system yet, "Paint" has been my go-to system for drawings of any sort. Nice-n-simple just like I like it. Kudos to you for further progressing with your personal education. Best regards, Allan
Parent - By kcd616 (***) Date 09-22-2015 06:03
Allan,
all about business
try my best to learn and help others
sincerely,
Kent
Parent - By Jarhead1 (**) Date 09-22-2015 18:39
- - By 803056 (*****) Date 09-22-2015 03:36
Since you are working with AutoCAD, try changing your units to fractions. They will be a better fit.
Remember your tolerances; any time you use a four place decimal, you have to have a means of measuring it. Would a welder normally use a dial caliper to layout a structural connection or would a wooden rule or metal tape measure be used?
Nice work my friend.
I'm still using AutoCAD 2000. I'm too tight with a buck to spring for an update that will set me back around $6K!
Parent - - By kcd616 (***) Date 09-22-2015 06:14
Al,
try draftsights.com
supposed to be easier than autoCAD
and FREE!!!!
btw: 1 of my reasons for collage
is low cost for member fees
asme, astm, asci all free for students
aws $15 for students
to get back with the best
for low cost
take it every minute
just my thoughts
sincerely,
Kent
Parent - By 803056 (*****) Date 09-22-2015 16:24
It is hard to say no to a bargain.
I stick with AutoCAD because many of my clients can use the same files. I did try a different program once, but found it to be useless and it only worked with Apple.
Parent - - By kcd616 (***) Date 09-26-2015 04:51
#2 drawing
but have not figured out how to do the passes like they
should be
ie #8 should be #2
and we all know how the others go
I am trying Al
I might learn in 20 years:red::eek::wink::surprised:
but doing my best
sincerely,
Kent
Attachment: kent2-1.jpg (40k)
Parent - - By 803056 (*****) Date 09-26-2015 13:21 Edited 09-27-2015 00:12
I do pretty much the same as you indicate. I do it as a multi-step process.
First I draw the groove, then I add the weld beads showing the joint penetration and depth of fusion. They are nothing more than a representation of what is required for most projects. The number of beads and the size of the beads may vary from joint to joint, so the sketch is nothing more than an idealized representation of what the welder will do.
Once all the beads are drawn, I use the cut function to remove the weld face of the initial bead. The weld face is remelted by successive weld beads, so this representation is more accurately represent what one would see if the groove was cut and macroetched. I do not represent the HAZ of each weld bead unless I am actually trying to show metallurgical features for a classroom presentation.
The size of the weld beads are dependent on the thickness of the joint and the diameter of the electrode used. Since you have a good number of years as a welder under your belt, you should have a pretty fair idea of the size of the weld bead that can be deposited in various welding positions. That is an advantage of someone with experience under the hood compare to someone that never struck an arc. You have a leg up on your completion my friend.
Parent - - By kcd616 (***) Date 09-27-2015 04:03
Al,
it is days under the hood:wink:
that 1971 huntsmen fiber shield:surprised::roll::lol:
I got at a yard sale:wink::eek::roll:
so I am only 18...got a college ID:wink::red::eek:
sincerely,
Kent
Parent - - By 803056 (*****) Date 09-27-2015 14:09 Edited 09-27-2015 14:12
I need to learn how to reduce the size of my sketches. The sketch above has half the details showing unless you scan across the page to see the part that hidden from view.
I draw the sketch using AutoCAD, then plot it as a pdf, crop the sketch to get rid of the white space, and then save it as a jpg. There is probably an easy way to resize it, but I'm at a loss as to how it is done.
Maybe you know the secret. Most college kids know these things. One is never too old to learn something new. It just takes a little longer to sink in.
Parent - - By electrode (***) Date 09-27-2015 15:17
Not sure whether or not that helps; but I would suggest using your image processing to either drop jpeg:
- resolution (pixels x pixels)
or
- size (width x height)
before embedding the image.
This at least is how I myself have tackled these well-known issues on this forum.
Others may have different ideas.
Parent - - By 803056 (*****) Date 09-27-2015 15:18 Edited 09-27-2015 15:23
I'm not sure Adobe Acrobat has that option, but thanks. I'll look to see if it is available.
That looks better!
Thanks - Al
Parent - By electrode (***) Date 09-27-2015 15:28
Positive. : )
Glad to learn that it worked.
Parent - - By kcd616 (***) Date 09-30-2015 19:34
Al,
tell me what I did wrong here
I know I FUBARED something
sincerely,
Kent
Attachment: kcd616.jpg (38k)
Parent - - By ctacker (****) Date 10-01-2015 00:01
Looks like your welder is a typical welder, slows down with each pass (notice each pass gets a little more volume), but at the end of the day, right before the buzzer, pass # 6, travel speed is increased to punch the clock in time.:lol:
I always noticed how slow people walk into work, but how energized they get when leaving.:lol::lol:.
Parent - By kcd616 (***) Date 10-01-2015 00:15
so correct
the cad program does not think like us
in the business
I wish I could write a program that does:sad:
sincerely,
Kent
Parent - By kcd616 (***) Date 10-01-2015 00:11 Edited 10-01-2015 00:16
one more
sincerely,
Kent
Attachment: kcd.jpg (33k)
