Harris does an adequate job with some parameters
http://www.harrisproductsgroup.com/en/Products/Alloys/Welding/Copper-Alloy/Silicon-Bronze-GMAW-MIG.aspxGMAW (MIG) Parameters (DC Reverse Polarity) Electrode Positive Spray transfer
Wire Diameter Amps Volts Argon (cfh) Wire Feed ipm
.030 130-150 21-23 25 460-500
.035 145-185 23-25 30 400-440
.045 195-215 26-28 30 280-310
1/16 260-280 27-30 40 150-210
AWS A5.7 ERCuSi-A, I would try .035 and .045 see what is fastest/best. If you already own a pulsing power supply, it can make for a very nice finished appearance, but regular spray x-fer is fine too
100% argon for most applications.
There are some specialty shielding gases out there that provide some benefits for high volume operations that demand best possible appearance, mostly on galvanneal automotive materials.
