Up Topic Welding Industry / General Welding Discussion / Stainless GMAW Gas Question
- - By marktski (**) Date 09-25-2015 17:49
I will be welding some stainless steel (old dinnerware) as a craft project.
I expect they will be used outside in the open. I plan to use .030 SS wire,
short circuiting transfer, the question is, if I choose to not use a tri-mix,
and opt for C-25, will I have major rusting problems? Any thoughts or
suggestions?
Parent - By Jarhead1 (**) Date 09-25-2015 18:01
Really? MIG? Let us know how it turns out.
Parent - By Lawrence (*****) Date 09-25-2015 21:10
C25 is not recommended for GMAW OR GTAW of stainless...
So you can expect ugly welds that will corrode more easily
Sorry to be a downer.
There are FCAW electrodes for stainless that work well with C25
Parent - By kcd616 (***) Date 09-25-2015 22:24
Lawrence is correct
just argon, imho ( ok Lar tell me how stupid I am:wink::red::eek:)
for small dinnerware
I would use gtaw myself
but that is my forte and feel more comfortable with
gmaw is better on the $ side
but your choice
sincerely,
Kent
- By mwmw (**) Date 09-26-2015 01:13
IF you are really set on gmaw then A1025 gas would be the ideal gas
