I know Everlast is sort of an off brand but has anyone on here tried one of the machines that has the Advanced AC pulse mode on it? Thoughts? Opinions?
A farmer friend of mine got one, he asked me to come over and help set it up for him.
The advanced pulse mode is pretty strange... it pulses between AC and DC-. You can adjust the AC wave about as well as any AC inverter but it has a DC- side that has a timing and amperage control.
It seemed like with some playing around that it could do things that "normal" AC couldn't... hard to describe but it seemed like everything melted in and flowed a bit easier. You could really dial down the DC+ etching effect and still obtain fusion and a clean bead.
It would dial right out of whack really easily though... too heavy on the DC- and light on the AC amps would result in a really sluggish skin covered weld, if not total oxidation and failure.
This is a link to one of their sites that explains the AC pulse pretty well...
http://www.everlastgenerators.com/blog/tig-welding-pulse-versus-advanced-pulse-part-2-2This was the machine I got to try out/set up.
http://www.everlastgenerators.com/product/tig-stick/powertig-255extApart from the strange pulse modes the machine was a fairly decent running inverter GTAW/SMAW unit. Plugged into 110V it topped out at 125amps. Plugged into 220V it gets up to 200 or 210...
no affiliation just intrigue over a strange new welding mode...
-Clif
