Up Topic Welding Industry / General Welding Discussion / Downdraft Tables
- - By Jarhead1 (**) Date 10-08-2015 18:31
Hello All,
Can anyone recommend a downdraft table supplier. Need qty (4) approx. 5' wide depth not that important.
Seen costs around $2000.00 for Bailreigh and $5000.00 Diversitech approx. same size.
Needs to be medium to heavy duty. Welding gussets to 3" x 4" x 10' long angles and thinking of combining two 5' units.
Need to keep cost down - this is a couple year job.
Has anyone use Bailreigh?
Thanks in advance...
Parent - - By kcd616 (***) Date 10-08-2015 19:33
Richard,
I have some Baileigh woodworking stuff
had some metalworking
mill, lathe, press
good stuff, at a good price
my plug for the month:eek::red::wink:
sincerely,
Kent
Parent - By Milton Gravitt (***) Date 10-09-2015 00:56
Where I use to work had 4 of these table and they are alright but you need to buy and the tooling with the tables if you don't buy the tooling along with the table they're not worth a dime.
                                           M.G.
