Up Topic Welding Industry / General Welding Discussion / Applied heat after stress relief
- - By marktski (**) Date 10-12-2015 18:34
Is there any reference or limit in the ASME code as to how much, if any, heat may be
applied to a vessel in the manufacturing state after stress relief has been performed?
I am refering to a vessel being built to section VIII Div I. As a general rule in the past,
when manufacturing earth moving equipment, 800 degrees was the limit I was given.
Any thoughts??
Parent - - By J.W. (*) Date 10-14-2015 17:40
SEE IF UG-78,UW38 AND UCS-56-F 1-6 HELP.
Parent - By marktski (**) Date 10-14-2015 18:11
Very helpful, thanks!
