I need to weld a collar onto a 3" dia. bucket pin (4140 PH) about 21" long. I'm using A36 (0.5" thick) for the collar, and making a 1.5" plug weld to connect the collar/flange to the end of the pin. After consulting the Lincoln Bible, I decided on using 309L filler (had a bunch leftover) and a 500° preheat on the end of the pin. I filled up the plug weld in around 12 passes or so, keeping my interpass temp around 500°. These will be used on a compactor like
this one.
I just sent the first two off, and have 10 more to do, but I wanted to ask the experts about my process. The collar just keeps the pin from falling out, but I always get paranoid about Q&T alloy steel. Is this approach reasonable or fubar?
