Hey All
Quick question for ya, we have here a PQR that tested a 27mm plate.. I have the test records, which show sucess with 4 transverse side bends, 2 reduced section tensile test and a few others.
My question is, can I use the setting/processes from this PQR to build a WPS for 11mm plate?
In table 4.2, page 139 of D1.1:2010 we see "WPS Qualification - CJP Groove Welds: Number and type of Test Specimens and Range of Thickness and Diameter Qualified (Dee 4.5) (Dimensions in millimeters)
Part 1 Tests on Plate shows
That if the Nominal Plate Thickness (T) Tested was 25 and over -> And there were 2 Reduced Section Tension (See fig 4.14), and 4 Side Bend (see fig 4.13), then the Nominal Plate thickness qualified is a Minimum of 3mm, and a maximum of Unlimited.
So...is it just that easy? I can write a WPS using these settings for an 11mm plate, as well as a separate with identical settings for a 30mm plate?
Are there any other factors I should consider?
Thanks!
