Ex. Part 2: When the PQR was created, 6 passes were made in total. And as we can imagine running these 6 same passes on 5mm of material seems a bit excessive. Is there a way to note "can be accomplished with a single pass per side?" I'm not finding anything in D1.1 that says "add or remove the number of passes" ?
You can write multiple WPS's off of one PQR. It's good practice for your 5MM weldment to have it's own WPS based off your existing supporting PQR.BUT with all of that under Electrical Characteristics 9)a) we see the condition of:
"An increase in heat input or volume of weld metal deposited per unit length of weld, over that qualified. The increase may be measured by either of the following: J/in = (Volts x Amps x 60) / Travel Speed
Weld Metal Volume - An increase in bead size, or a decrease in the length of weld bead per unity length of electrode.
Doesn't this nullify any ability to increase the amps, volts, as those increase the heat input?
Not necessarily. With the increase in volts and amps can come the increase in travel speeds that can in turn keep your heat input in check with the essential variables. Travel speed is also an essential variable so everything has to be monitored so when audited you are within spec.Just...so very confused as to what is going on here. Really starting to question how I passed the CWI exam....
Where and with who did you take your CWI exam? Just messin with ya man! Don't sweat it brotha. We all started somewhere. Keep studying, asking questions, and learning on here. There is so much one can learn on these forums.
