We have a PQR for a CJP weld, which was carried out using 25mm thick S355 J2+N, which the test piece was CVN tested.
My question is, does our PQR cover use for all fillet welds, both multi and single run, as per table 4.2, because our original test piece was CVN tested, therefore no supplementary testing is required and therefore annex III and table 4.6 are not applicable?
Kind regards
Andy
