We have a WPS for GMAW in the G1,F1,F2 positions for AWS ,and we just got a ABS WPS approval of a Fillet weld in the F1,F2 positions , we just added a rev. to the original , with notes from the ABS surveyor that the WPS he/she stamped was for 1/4" fillet welds only(we only did a single sided test plate ,as per surveyors wish), and on our WPQR we did a single sided 5/16" fillet weld plate(fig.4.37) -----now my question when I make up the WPQR should I also make notes that state it is for single fillet weld only, seeing that we didn't do a multi-pass coupon (fig.4.19 ,p174) for the WPS .
The notation 1G, 1F, 2G, 2F, etc. denote test positions, not production positions. Production positions are flat, horizontal, vertical, and overhead.
There is also a question with regards to your acronyms. What document are you defining with the abbreviation WPQR?
Keep in mind that the test assemblies for ABS are not always identical to AWS.
