Up Topic Welding Industry / ASME Codes / Welder qualifications
- - By Richman (**) Date 11-20-2015 18:30 Edited 11-23-2015 00:02
Can someone help me interpret the below info;
In QW-404.23 it states, A change from one of the following filler
metal product forms to another:
(a) bare (solid) or metal cored
(b) flux cored
(c) flux coated solid or metal cored
(d) powder
Kindly correct me if I am wrong. My interpretation on above subject QW, if the welder/s is qualified under sction IX using solid wire he can qualified to weld using flux coated wire Without violation on the code.
Thank.
Parent - By 803056 (*****) Date 11-22-2015 15:45
Basically, ASME differentiates between different welding processes such as FCAW and GMAW by the type of electrode used, i.e., solid vs. tubular.
Parent - - By Don56 (**) Date 11-24-2015 21:08
If a welder is qualified to weld by using solid wire he is also qualified to weld using metal cored.
If he qualified with solid wire he is NOT qualified to weld with flux coated  solid wire nor flux coated metal cored wire.
Parent - - By Richman (**) Date 11-24-2015 23:59
What if Sir, the welder/s is qualified with flux coated wire can he weld using solid wire or NOT?
Parent - By ssbn727 (*****) Date 11-25-2015 00:39
No.
