The first thing to come to mind is properly aging the test coupon after welding to permit the hydrogen to effuse from the weld. How long did you allow the welded coupon to sit before testing it?
Any obvious defects on the fractured surfaces? Other than that, I've got nothing.
By welderbrent
Date 11-22-2015 23:21
Edited 11-22-2015 23:25
You did use the correct preheat? Seeing they are not low hydrogen electrodes? Just checking.
Oh, how forgetful of me:
ASME SFA 5.1 does not list an electrode E7010. Do you mean E7018?
You may soak the coupons for up to 48 hours at 90-105 deg. C before tensile testing.
What do you mean by MS plate?
there seems a lot of confusion here.
P1 is a base metal designation and yet you are qualifying filler?
And why would you qualify two different fillers simultaneously?
Especially when they come from separate specifications.
Filler pads are stacked so that dilution from the base metal is minimized.
