Thank you AL for your valuable response,,,,,as we were going to fabricate a batching plant structure...in that the the material spec is bs en S235jr....i first plan to use a prequalified wps .... but on table 3.1 (aws d1.1 2010) its equivalent astm material ( A283C) is not listed ...so finally the only option is to qualify the wps am i right????
Regards,
Jibin
