Dear experts,
I am new member on this forum.
I need your advise for the below case :
We have 2 tanks with same design and configuration.
The first shell course and annular plate is SA516-Gr. 70(N) which is P1 Gr. 2. Shell plate thickness is 13 mm and annular also 13 mm. There is backing strip in annular.
The second shell course till top shell courses are A283C which is P1 Gr. 1. Shell plate thickness is 11 mm , 9 mm, 7 mm and the top course is 6 mm.
The bottom plates are A283C.
We have clean out door attached on the first shell course so we need to PWHT this assembly as required by API 650
The WPS shall be per ASME Section IX.
In WPS under PWHT block : I will state PWHT only for the shell with clean out door.
In WPS under material block : I will state P1 Group 1 and Group 2 TO P1 Group 1 and Group 1
In Thickness range block : I will state 6 mm to 13 mm. The PQR coupons will be plate 10 mm thick A516-Gr. 70 (N).
It is allowed to make only 1 WPS above case ? But I will make 2 PQR coupons i.e. 1 coupon for non PWHT and other for PWHT.
Inside the tank there is pipe 2" and 4" and 6". The requirement for butt weld joint for this pipe is GTAW root pass and SMAW the next pasess.
To cover butt weld joint on these pipe I will make another WPS for GTAW + SMAW. The PQR coupon will be plate 10 mm thick A283C.
Your response is highly appreciated.
Syah
