Up Topic American Welding Society Services / Technical Standards & Publications / Welder Qualification; CWI present? 4.19.3 (D1.1:2010)
- - By Bowler_Hat (**) Date 12-28-2015 19:52
Hey All,
Quick question, when a welder is qualified for production, the person who is going to sign off on the test needs to be present for the test correct?
Sounds redundant, just having a sanity check here.
More important, I'm trying to grasp the abilities detailed in 4.19.3 Welder and Welding Operator Qualification Through WPS Qualification.
Which states:
"A welder or welding operator may also be qualified by welding a satisfactory WPS qualification test plate, pipe or tubing that meets the requirements of 4.9."
I'm under the impression that welding with the same parameters as were made on a WPS qualification test plate and two side bends, is not the same as subjecting it to the same extensive testing that allowed this WPS to be used.
Thoughts on clarification? Thanks!
Parent - - By Lawrence (*****) Date 12-28-2015 20:36
Hi Bowler
That's actually quite a few questions (good ones) and I think there may be some confusion as to terms.
The person "Certifying or singing" a welder performance qualification test report needs to be the person representing the company doing the work... Not necessarily a CWI or even present during the testing.
In my opinion the person who *observes* needs to sign for the portion that they observed; meaning different people can witness the actual test, do the visual examination and the RT or destructive testing.. or the same person can.. As long as each requirement as a place to sign you are compliant...   *AFTER THAT* the company representative must sign off stating that code was followed for every step.
The second part of your post:
"I'm under the impression that welding with the same parameters as were made on a WPS qualification test plate and two side bends, is not the same as subjecting it to the same extensive testing that allowed this WPS to be used."
A "WPS qualification test plate" is exactly the same plate that is used in compliance with Clause 4 to perform the extensive testing that allows a WPS to be used.    So we can not positively be sure what you are asking about.
There are differences between performance and procedure qualification testing in clause 4... And I *think* this is what you are trying to get at.  The test assemblies are different, the essential variables are different and the inspection regimen is different.
A welder performance qualification test may or may not be driven by a production PQR or even a production WPS...   For a performance qualification test, it is essential to have a written WPS that is compliant with the performance test assembly for the process, position and transfer mode of the test to be conducted.   Once a welder is qualified, they may do production on anything within the limits of Table 4.12 and 4.10
While there is GREAT wisdom in making performance testing emulate production work as closely as possible.. The code does not address standard practices to such an extent.
Anyhow... I think you are going to get great answers to all your questions... We just need to sharpen them up a little more.
Parent - By 803056 (*****) Date 12-28-2015 22:21
Nice response Lawrence.
If I can add:
The intent of procedure qualification is to demonstrate the combination of welding process, base metal, filler metal, shielding gas, etc. will produce a weld that meet the minimum mechanical properties required by the welding standard. The test regiment for a grooved plate assembly is extensive and can includes: visual, NDE (AWS D1.1, D1.5, NAVSEA, etc.), guided bend tests, reduced section tensile testing, and notch toughness (when required).
The intent of performance qualification is to demonstrate the welder can deposit a sound weld when following a qualified or prequalified WPS (AWS D1.1, D1.5, etc.). The test regiment is abbreviated since there is no need to verified the WPS can produce the mechanical properties required by the welding standards.
The contractor must accept responsibility for both the procedure qualification and performance qualification. The contractor's  signature in the space we typically call the certification is the activity performed by the contractor signifying they are accepting legal responsibility for the procedure qualification record, welding procedure specification, and or the performance qualification record.
Different welding standards invoke different requirements for qualifying the WPS and the welder. AWS D1.1 allows the Engineer to accept previous qualification for the welder and in the case of the WPS; if you purchase a license from AWS. Interesting that you can buy AWS' WPSs but they will not recognize a WPS qualified by another entity. Am I the only one that sees a conflict of interest with this arrangement?
ASME Section IX places the responsibility for qualifying the welder and the WPS squarely on the contractor's shoulders. Generally, ASME does not recognize qualification and certification by third parties such as an ATF or even AWS. Granted, there are exceptions, but usually the contractor has to supervise the welding of test coupon when qualifying the procedure or the welder.
Few welding standards require the WPS or the welder performance test be witnessed by a CWI. If CWI involvement is required, it is usually a customer imposed requirement.
Personal opinion: the CWI should only sign the test reports indicating what activities the CWI performed, i.e., witness the test, perform the visual, perform the NDE (when qualified to do so), and perform mechanical testing. Generally the CWI should not sign the certification statement unless the CWI is a direct employee of the contractor and the CWI is authorized to represent the contractor. In other words, a CWI that works for a third party and is not employed by the contractor should not sign the certification statement on behalf of the contractor.
Few CWIs understand the legal ramifications of signing performance test records, WPSs, or PQRs. As SCWI I witness the welding and I perform the tests used to evaluate the test assemblies. I sign for those activities, but I do not certify the welder or the WPS or PQR.
