Dear experts,
Our contract agreement is WPS / PQR for vertical with SMAW must be impact tested even by the code we are exempted for this impact test.
Vertical seam on our shell plate would be :
a. P1 Gr 2 welded to P 1 Gr 2. Shell plate thickness range from 6 to 37 mm.
b. P1 Gr.1 welded to P1 Gr. 1. Shell plate thickness range from 6 to 8 mm.
All these vertical will be welded by SMAW process.
My plan is : make PQR with one test coupon with P1 material and thickness is 19 mm. This coupon will be tensile stressed, banding stressed and impact tested.
The problem is our client welding engineer insist to provide 3 PQR coupons with various thicknesses. He said due to impact test we need to provide 3 coupons with different thicknesses. He can't explain to me which standard address this requirement.
I can't find that requirement in API 650 nor ASME Section IX.
Your comments is highly appreciated.
Syah
