Up Topic Welding Industry / ASME Codes / ASME brazing question
- - By jsdwelder (***) Date 01-07-2016 21:13
To anyone familiar with ASME brazing spec.'s, can you tell me if there are diameter limits applicable to performance brazing qualifications? I cannot seem to find anything in the QW section of ASME IX that addresses diameter limits. Thanks in advance!!
Parent - By js55 (*****) Date 01-08-2016 13:29
That's because it isn't in QW. Its in QB.
Parent - - By fschweighardt (***) Date 01-08-2016 13:38
Look in the QB section for starters:lol:
But to answer your question, the only essential variables for brazing performance qual that come close is base metal thickness QB-402.3, which refers you to QB-452, and overlap of the joint QB-408.1 (all references are 2010 edition, all I have with me)
There are no diameter rules for performance.  Procedure qual has diameter rules.
We do a fair amount of brazing, and we add additional restrictions on max diameter for performance qual.
Parent - - By fschweighardt (***) Date 01-08-2016 13:39
well Jeff beat me to the QB wisecrack
Parent - - By jsdwelder (***) Date 01-08-2016 16:45
Sorry guys, I meant QB. That is where I was looking, just posted it incorrectly. Thanks.
Parent - By fschweighardt (***) Date 01-08-2016 16:51
just giving you crap
Parent - - By js55 (*****) Date 01-08-2016 17:13
Nobody gets any slack in here. Even the old timers.
Parent - - By fschweighardt (***) Date 01-08-2016 19:00
maybe especially the old timers
Parent - - By jsdwelder (***) Date 01-09-2016 14:16
Where has all the time gone between newbie and old timer?:confused:
Parent - By Kix (****) Date 01-19-2016 16:45
Just for informational purposes QB-251 are all essential variables for Brazing procedure qualification and QB-351 are all essential variables for brazing performance qualification. Hope you're off and running. :wink:
Kix
