Syah,
It depends. For the most part you are talking about impact testing of the weld procedure specification, which can include weld metal and heat affected zone, which represents base metal. A few Codes require unaffected base metal tests(Section III and B31T to name two), but for most codes this is rare. Base metal 'qualification' will be determined by the tables and the graphs and service temperature allowances.
