Up Topic Welding Industry / Technical Discussions / Consumable for Welding S355jr
- - By JP (*) Date 01-25-2016 12:28
Dear Experts,
Shall we can use E7016  for open root welding S355jr (ASTM A572 Gr 50)
Awaiting reply,
Regards,
JP
Parent - By js55 (*****) Date 01-25-2016 13:34
Code wise you can (as long as you qualify it correctly and have engineered it correctly), but it requires a specific welder skill set that is unusual. The question is, why would you want to?
- By 803056 (*****) Date 01-25-2016 15:18
If the governing welding standard is AWS D1.1/D1.1M, E7015, 7016, 7018, or 7028 are all considered to be matching filler metals for ASTM A572 Gr 50.
If you are using a base metal that is not listed by Table 3.1 (found in D1.1), the WPS must be qualified by testing in accordance with Clause 4 parts A and B unless the Engineer/Owner authorizes the inclusion of the unlisted base metal as prequalified.
