Working for a customer, we shot some digital RT on a part. Part is 6061-T6 AL, it is a CJP weld with a backing. Now when we did RT we got some of the typical lines you would see on a CJP weld with a backing. Not so so much of "wagon tracks" per say but straight lines with intermittent spots of what appear to be possible slight suck back or maybe even undercut at the root upwards. We cant remove the backing strip, all we have is the RT to look at. Now myself a lowly level 1 RT, I dont have to make the call. But asking as a visual inspector, Had they removed the backing and it is VT'd, would any type of below surface on the root be classified in undercut? or profile? maybe even underfill in a way since the total filling of the groove is not full? Acceptance on this weld per D1.2 2014 per table 5.3 there are a few different ways to approach it. Curious any input.
Now this one one frame of 24 there are much worse areas but I just wanted to show the idea. The part failed in RT in many places.
I wont get to cut the backing, just asking hypothetically if we did how you might approach it.
here is an image ------->
http://imgur.com/a/BqKmrIve circled other problem areas
J
