Up Topic Welding Industry / Inspection & Qualification / Welder Qualification for set through nozzle
- - By Bijit Sarkar (*) Date 02-19-2016 11:42
If my welder is qualified with groove, which means qualified for pipe of diameter 73mm and above. Can I use that welder to weld set through nozzle, if nozzle diameter is less than 73mm, lets say 50mm? My doubt is due to the groove present in shell not on nozzle.
Parent - By welderbrent (*****) Date 02-20-2016 01:38
Only enter your question once in one forum section please.
