OK, that is a bit more clear.
In a former life working for Kidde, I inspected code pressure vessels (post code inspection at manufacturer) used for dry chemical systems. We would run heat in them for a couple of days, then seal them up with a humidity sensor inside to ensure they were dry. It's been about 10 years, but if memory serves me well, the spec was about 20% humidity. We would then remove the sensor, drop in a large desiccant pack for transport to our main plant. The change in temperature and humidity from Port Arthur Texas to winter in Pennsylvania was sometimes rather dramatic.
Hope this helps.
