"....for 'PREHEAT' you won't want or need to be anywhere close to 1200°. For heavier members 225° is the top except for special situations which can require temps on up to the 4-600° range.
Now, for heat cambering, straightening, and other operation you may well need more heat and even close to 1000-1200°. But, not for preheat." -Brent
Agreed, preheat need not to exceed 225°F for low hydrogen electrodes/processes, and 300°F for others(AWS Table 3.2-- speaking of preheating structural steel, mild steel). Also agree with the special situations requiring a bit more heat.
I answered pretty quickly on the way out the door to another job.....I should have explained things a bit better. Thanks for the help Brent.
