The material used to manufacture the grinding disk or stone may not be a source of hydrogen, but it is impossible to count the times I've seen people use bee's wax on the tools to prevent them from getting "loaded" with aluminum particles. What comes next? Welding of course and the resulting porosity!
Frank Armao also says:
"Minimizing porosity is mostly about cleanliness and housekeeping. There are actually many possible causes of porosity. Following are the top four culprits and how to prevent them from happening.
Poor Preweld Cleaning. Be sure to degrease the part before you weld. Wipe down the surface of the material with a clean, lint-free rag saturated with a good degreasing solvent. Acetone and toluene are among the best. Alcohols are not good degreasers and should not be used for preweld cleaning. Following degreasing, the aluminum surface is then deoxidized, usually by using a stainless steel wire brush. Mistakes here are the most common cause of porosity.
Insufficient Shielding Gas Flow Rate. For gas metal arc welding (GMAW), the flow rate should be at least 35 SCFH, although flow rates up to 60 SCFH can be used, especially with big gas nozzles. Argon/helium gas mixtures require even higher flow rates. For gas tungsten arc welding (GTAW), the flow rate should be at least 25 SCFH.
Incorrect Nozzle-to-Work Distance. Simply put, this distance should be as small as possible, preferably in the range of ½ to 5/8 in. Longer nozzle-to-work distances can suck in surrounding air and other contaminants."
Improper Gun Angle. Aluminum welding always requires a leading gun angle. If you try to use a drag angle or even a 90-degree angle, you will get porosity in your welds.
