Up Topic Welding Industry / General Welding Discussion / Shop Tools Defined.
- - By Superflux (****) Date 03-21-2016 09:32
Found this and though it might be entertaining. It seemed to be specific for auto mechanics, but most of us can relate.
Kinda get the minds off all that serious high techno stuff for a minute.
Feel free to add more.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
WIRE WHEEL: Cleans rust and paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in less time than it takes you to say, 'Oh sh--!'
BAND SAW: A large stationary power saw primarily used by most shops to cut perfectly good sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the expensive metal or plastic surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic
parts. Especially useful for slicing work clothes, but only while in use.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
SON-OF-A-***** TOOL: Any handy tool that you grab and throw across the garage while yelling 'SON-OF-A-*****!' at the top of your lungs. It is also, most often, the next tool that you will need. Of course it will only be needed if lost or irreparably damaged after the aforementioned aerodynamic property evaluation.
Parent - - By 522029 (***) Date 03-21-2016 13:39
That's pretty good!
Griff
Parent - - By Milton Gravitt (***) Date 03-21-2016 23:17
I think I have used everyone of those tools. LMAO
   M.G.
Parent - By Tommyjoking (****) Date 03-22-2016 01:33
I have owned multiple instances of all those tools and used them according to definition and those endeavors of my own sick creation.
Parent - By Cumminsguy71 (*****) Date 03-23-2016 13:04
I can relate to every one of those!
- - By 803056 (*****) Date 03-22-2016 01:34
I love this Forum!
Parent - By Stringer (***) Date 03-22-2016 23:49
Blueprint: A place to put coffee and sparks.
