Up Topic Welding Industry / General Welding Discussion / Bench Top Work Positioner
- - By amalgam (*) Date 04-17-2003 05:44
[deleted]
Parent - - By TRC (***) Date 04-18-2003 01:14
Welcome, I don't have any drawings for a positioner but I have made several in the past. Just use your imagination and start with a supply house cataloge such as Graingers. All you need is an AC/DC gearmotor and speed controler. A couple pillow blocks and cold rolled round stock for the shafts (1"), some # 35 chain and sprockets. Some channel for a set of pipe rollers or some square tube or angle for a table top positioner. Jetline uses a piece of 10 or 12" square tube for their housing, everything is inside and protected from sparks. Don't forget to design in some safety guards as well.
Plan on spending around $300. Look at manufactures such as Atlas for basic design ideas.
Parent - - By amalgam (*) Date 04-19-2003 04:35
[deleted]
Parent - By GRoberts (***) Date 04-21-2003 14:27
You could probably do it for a lot less if you can pick up your parts at a local surplus/repair place, or at the Surplus Center in Nebraska. They have about everything a guy could want to build machines like that.
