Up Topic Welding Industry / General Welding Discussion / What is the right welding AWS symbol for the sketch attached
- - By SIVAGANESH Date 04-19-2016 09:46
Someone please teach me what is the right welding symbol for the drawing in the figure attached. https://www.facebook.com/photo.php?fbid=961315313976153&set=a.253968734710818.57621.100002930813841&type=3&theater
Parent - By 803056 (*****) Date 04-19-2016 10:25
Try this. Remember to include the weld size and length.
Parent - - By jwright650 (*****) Date 04-19-2016 12:21
Like Al stated, include the weld size and length,
...note that if no length is shown, it is implied that the weld shall be continuous.
If an intermittent fillet weld is intended, then also show the frequency. ie 2"-12" meaning place a two inch weld every twelve inches
Parent - - By 357max (***) Date 04-19-2016 18:26
As JW stated and for additional clarification the 2" length of intermittent weld 12" spacing would be center to center of the 2" length of intermittent weld and 12" spacing (pitch) not end to beginning of intermittent weld segments. AWS has a very thorough specification A2.4 2012 Standard Symbols for Welding, Brazing, and Nondestructive Examination. It also has an annex on the ISO 2553 Welding Symbols.
Parent - - By FrankLee11 Date 05-02-2016 08:01 Edited 05-03-2016 20:49
deleted by moderator
Parent - - By 803056 (*****) Date 05-02-2016 23:52
I'm simply at a loss for words!
Parent - By twalker Date 05-03-2016 19:04 Edited 05-03-2016 21:14
As alluded to in general comment from the other posts, it would be Impossible to accurately sketch a proper welding symbol from this one view. First, as already stated, we have no idea if these are continuous fillet welds or intermittent fillet welds. Also, if they are intermittent fillet welds are they staggered? My answer to the original question is to not read into a welding symbol what isn’t there. The only thoughtful answer would be to contact the customer and have them red line the drawing. Trying to outguess the engineer’s intent will most often lead to inspector malpractice. In a case like this, the customer would most probably have standing before the court. Read don’t write :roll:  On another note, the question was welding symbol not weld symbol :eek:
