Up Topic American Welding Society Services / Certifications / Duties and Authorities of AWS / CSWIP Welding Inspector
- - By Nalla (***) Date 04-30-2016 12:34
Dear Sirs
Pls advise where i can perform this information
For example-
Can a Certified AWS  WI / CSWIP Level 3.1Welding Inspector can review and endorse/approve below mentioned-
1- WPS/PQRs
2- Welder Certificates
3- Welding Consumable Certificates
4- Base Material Mill Certificates
5- Shielding/Purging Gas Conformity Certificates
6- Destructive Test Reports
7- NDT Reports
Client insist above can only performed by AWS/CSWIP Senior Welding Inspectors
Thanks in advance
Parent - By 803056 (*****) Date 04-30-2016 17:31
The authority of the CWI is limited by the authority delegated by the Owner or the Owner's Engineer. AWS B5.1, Table 1, lists the job responsibilities a WI (Welding Inspector/CWI) or SWI (Senior WI or SCWI) should be capable of performing. However, as the third party inspector and if the governing document is AWS D1.1, the duties of the Verification Inspector (TPI) are quite limited.
There are many instances where the Engineer (again, per D1.1) can and does delegate certain responsibilities to the CWI/SCWI.
As for the CSWIP, not a clue.
