Up Topic Chit-Chat & Non-Welding Discussion / Off-Topic Bar and Grill / Empty spool ideas
- - By WUVIE Date 05-17-2016 20:52 Edited 05-17-2016 21:00
Greetings! :grin:
I came across this website when searching for crafts using empty welding wire spools.
Just thought I would share my latest project with you, and maybe inspire a few of you to
make something similar. :cool:
http://www.instructables.com/id/How-to-Make-a-Trash-to-Treasure-Bird-Feeder/
Thank you for allowing me to share.
Parent - - By Paladin (***) Date 05-18-2016 01:54
Nicely done.
Floyd
Parent - By WUVIE Date 05-18-2016 18:31
Hello, Floyd, thank you! :smile:
Parent - - By TimGary (****) Date 05-18-2016 13:43
I use those as ideal skillet holders in a camp fire.
You can either put it directly in the fire, or if you want to moderate the cooking heat, place it close to the fire and shovel an appropriate amount of coals into the spool.
Tim
Parent - By WUVIE Date 05-18-2016 18:30
I like that idea, thank you! :grin:
Parent - By 357max (***) Date 05-20-2016 02:53
Three 48-60 inch lengths of rebar and the four spools with centers cut out and then stack the spools & weld to rebar make indestructable tomato cages
Parent - By 803056 (*****) Date 05-24-2016 01:23
Nice.
