Up Topic Welding Industry / Welding Fundamentals / AWS D1.1 DEFINITIONS
- - By Justneed2know Date 06-06-2016 16:29
AWS D1.1  - what is meant by "out-of-position" weld?    "  ...7/16 in or less in diameter for out-of-position welds"
Parent - - By HJLBX Date 06-06-2016 16:47
"In position" = welding in the flat position
When welding “out of position” (i.e., horizontal, vertical, overhead positions), you are welding against gravity. Now you are much more limited as to the size of the molten puddle you can carry; the puddle can run and\or "mis-behave" due to the force of gravity pulling on the molten puddle.
Parent - - By Justneed2know Date 06-06-2016 18:11
Thanks
Parent - By welderbrent (*****) Date 06-06-2016 23:45
You also have answers in another post you made on this subject.  Please, only post a question in one thread.  It can really confuse some discussions to have people responding in different locations.
Oh, thank you for starting your own thread here...that is far preferred to adding your question on to someone else's existing thread.
Brent
Parent - By pipewelder_1999 (****) Date 06-08-2016 13:07
Not to mention the PM.  IS this a test question or homework assignment?
