Up Topic Welding Industry / Welding Documents & Downloads / Supports welding procedure
- - By Raman-Khald Date 06-23-2016 21:53
i need supports welding procedure or guidelines to issuing procedure because client want that???????????
Parent - By TimGary (****) Date 06-24-2016 12:30
You need to supply more details if you want your question to be answered.
Just a guess -
Welding Procedure Specifications (WPS), which are a list of instructions concerning how to make a particular code compliant weld, are supported by Procedure Qualification Records (PQR), which is a record of the testing performed to validate the welding parameters detailed in the WPS.
Tim
