By ArtR
Date 04-26-2003 17:56
You will need to qualify your welders to ASME Section IX.
ASME Section VIII, B31.1 and B31.3 are the fabrication codes for pressure vessels, power piping and process piping respectively. All three require procedures and personnel to be qualified to ASME Section IX.
ASME Section IX is the qualification standard for welding and brazing procedures, welders, brazers, and welding and brazing operators. See ASME IX QW-304 for the type of test required for welders. Bend tests and visual examination are required. X-rays may be used as an alternate for certain processes and materials only.
