I have a doubt, whether to apply Ultrasonic or radiography testing first Is there a sequence to apply these both in any code or any advantages to follow the sequence.
When both are done on the same joint, it is generally more economical to make sure the weld is UT acceptable before RT, simply because UT is generally simpler to perform and less expensive than RT.
