Up Topic Welding Industry / General Welding Discussion / GTAW and GMAW Macro etch photos
- - By MRWeldSoCal (***) Date 10-17-2016 08:46
Hey everyone long time since I have been on.  I have been super busy teaching and working.
I have here a very large weld analysis job I just wrapped up.  I ended up sampling over 150 welds, each weld 2 sides, a photo for each side and writing 150 reports so my mind is slightly lost. The good news is I couldn't have ended up with better example photos from doing all this.  I organized them from GTAW and GMAW.  There is A LOT of lack of root fusion, excessive penetration, under bead cracking, large cracks, fine cracks, suck back and they are all in great detail so I hope you all enjoy! ALL ALUMINUM! let me know what you think!
Jordan
GMAW-----> http://imgur.com/a/RiqVf
GTAW-----> http://imgur.com/a/SAEj0
Parent - - By 803056 (*****) Date 10-17-2016 11:57
Nice photos Jordan.
What welding standard was being used for the actual welding and would you consider "donating" some of them to my subcommittee  on visual inspection of welds?
Parent - - By MRWeldSoCal (***) Date 10-17-2016 16:18 Edited 10-17-2016 16:21
Of course anything for you Al.  These were to D8.14 2000, and D8.8 94.
J. Maxwell
Parent - - By 803056 (*****) Date 10-17-2016 18:52
Application - Automotive
Aluminum - Almost a metal, endurance limit, there is none, it will fail if cyclically load.
Automobiles - subject to cyclic loads - welded aluminum components will fail sooner rather than later.
Just a few thoughts that flashed through my mind.
Parent - By MRWeldSoCal (***) Date 10-17-2016 20:51
My thoughts exactly.  I was just there to do the research.
