First, start with the big come, you know used in vehicles, trains, aviation products, stainless steel is the kind? 301 is the humble name of the representative of stainless steel products, its characteristic is the cold tensile strength increased without Magnetic, but there is magnetic after processing.
Second, and we are closely related to the tableware, cabinets, bathtubs and other products of 304 steel, the name is very familiar with it, we generally go to the building materials into the purchase of decoration products will say that our shopping guide is 304 stainless steel. The steel is relatively stable performance, heat resistance and low temperature are very powerful from -196 degrees Celsius to 800 degrees Celsius it can control. But because of too stable for bending is not suitable for modeling.
stainless steel sheet priceThird, the kettle, door handles, vegetables pots with the 304Cu, which just anti-drawing performance and anti-crack properties are great to meet the 304 steel bending weaknesses can not be greater.
Metal Supplier in China - Jaway MetalFourth, the washing machine, automobile exhaust pipe, stainless steel pot with the 436L of the steel, this model has just good heat resistance, and processing and welding performance, used in doing these products is appropriate.
Stainless Steel suppliers,steel sheets
