Up Topic Welding Industry / General Welding Discussion / Classic 300d
- - By Kaleb.d Date 10-20-2016 01:16
My classic 300d has started to act up,I was running it all day and I turned it off and when I went back to start it up it wouldn't start I taped the starter and it started but it only runs for maybe 30-60 seconds when the project engine light Come on and it shuts off, I turn the ignition off to reset it and it starts right up then does the same thing, and suggestions?
Parent - By roykfahey Date 11-08-2016 04:24
Thanks for sharing this info with us.
- - By theweldor (*) Date 11-09-2016 00:56
If it has Murphy switches. It is very possible one of the sensors went bad. If you have a wiring diagram look threw it and follow those circuits.
Parent - By Tommyjoking (****) Date 12-01-2016 03:01
Agreed......probably oil pressure switch or your pumps bad.....either way saves you a lot of money.
