Up Topic Welding Industry / Technical Discussions / Why xray is limited to lower thickness
- - By purode333 Date 11-16-2016 05:55
Dear sir,
Can you explain me, the technical reason behind, why xray is limited to lower thickness I.e below 5mm.
We know the contrast and sensitivity, we get better, but if we use good film quality like D4 and D2, and increase the expouser time in gamma ray, would we get good rt.
Pls explain exact and geniune reason why
Parent - - By Tyrone (***) Date 11-16-2016 12:07
Hey Purode,
What is your gamma source?
Tyrone
Parent - - By purode333 Date 11-16-2016 13:52
Ir 192
Parent - - By Tyrone (***) Date 11-17-2016 12:36
For carbon steel, max. thickness is approximately 2.5″ for Iridium 192
Tyrone
Parent - By purode333 Date 11-17-2016 13:13
Sir, my question is regarding xray limitation.
Parent - By MBSims (****) Date 11-24-2016 18:41
Metal thickness is only limited by the strength of the x-ray tube.
http://www.twi-global.com/technical-knowledge/job-knowledge/radiography-124/
