Per ASME, the issue is the thickness of the joint and the deposited weld thickness, not the number of layers or beads. The exception would be if there is a restriction on heat input the production weld where the travel speed, voltage, and amperage is restricted.
The welder taking the performance test must follow a qualified WPS, not the PQR. If that WPS has limits on the heat input, the welder must comply. However, if the WPS used for qualification had no restrictions on the heat input, the welder can use as many or as few beads as needed to fill the joint. The qualification is valid for production welds with or without heat input restrictions, with or without PWHT.
Once the welder is qualified, he must comply with the WPS used for production which may be different from the WPS used for qualification, If the production WPS imposes restrictions on the heat input or if there are limits on the size of the individual weld beads, the welder must work within the limits of the production WPS.
It is not uncommon for the WPS to include sketches of the permissible joint details. The sketch may include weld beads as representative, but only as a guide, not as a requirement for the number of weld beads that must be used.
Again, we are speaking about ASME Section IX requirements as supplemented by the requirements imposed by the construction code.
