Up Topic Welding Industry / Technical Discussions / weld ripples
- - By Rakesh Mishra Date 02-04-2017 15:23
Sir,
I am working as an Engg. in fabrication industry(refinery & adible oil equipments manufacturing industry)
our company first time ever conduct third party inspection schedule.
& inspector fails All circumferential & long seam welding because of its weld ripples thk. & height not match as per code.
(shell thk. 8 mm(MOC S.S 304/316)
can anybody please guide me what required size of weld ripples required.
Parent - - By 46.00 (****) Date 02-04-2017 19:00
Can you supply code you are working to? Process used etc. As much info as possible. Then maybe someone can help.
Parent - By 803056 (*****) Date 02-05-2017 15:47
Every welding standard and code has specific acceptance criteria. One must know what standard is being used to provide a valid  response.
Even ASME piping codes can have multiple responses to this inquiry depending on the operating temperature or service class. A piping system operating at high temperature or classified for high pressure fluid service is more restrictive than for other applications.
