Up Topic Welding Industry / Technical Discussions / TIG Welding Copper
- - By jon20013 (*****) Date 05-07-2003 13:34
My boss has a marine part (part of a supercharger for a friends boat). The assembly is mainly copper-coated carbon steel however there is an outlet which is copper (I assume for heat disspation coming off the supercharger). The copper outlet appears to be a forging and is cracked nearly completely around. We would like to try to TIG weld it, it's not a huge deal if we're unsuccessful because it will likely need replacement anyway. Any suggestions as to technique would be most appreciated!
Parent - By colins (*) Date 05-07-2003 20:07
You may want to look at brasing it.
colin
Parent - By fineorl Date 05-09-2003 23:42
I have used standard house wire to TIG weld freeze seal jackets for piping repairs. This may be an option for you. Good Luck
