I have been welding SA335 P91 pipes of OD 558 and thickness around 80 to 90 mm.Root pass is by Tig process followed by two layers of SMAW welding.I also purge the joint with argon to prevent root oxidation while welding .Subsequently by SubArc Process to complete the welding .After PWHT radiography is taken which does not show any indication .How ever the UT exam shows indications mostly 3 to 10 mm from the root .Before UT grinding is done on the inside of the pipe to smoothen out any excess penetration . What could the the problem and the solution ?
