Hi All,
Request you to kindly assist me with welding procedure sequence for welding Carbon Steel of 200mm thickness to Brass of 6 mm thick using GTAW. Filler used is 50% Ag TIG filler.
Type of joint is LAP joint.
Please do the needful at the earliest.
Thanks in advance.
