Up Topic Welding Industry / Technical Discussions / AWS D1.1 ambiguity in qualification of WPS and welder
- - By Mayur (*) Date 03-20-2017 08:38 Edited 03-20-2017 08:40
Dear All,
I need to use AWS D1.1 - 2000 'Structural welding code'. I kindly request you to help me understand qualification of WPS and Welder:
1. Shall pre-qualified WPS to be used for welder qualification purpose be mandatory approved by customer / engineer ? Engineer or customer representative has not yet been decided for the contract. I want to qualify a few welders using prequalified WPS. Currently, no engineer / customer representative is there to approve it.May I qualify welders using well written prequalified WPS wihich has not been approved by the engineer yet? May I qualify welders using the same and later I make it approved?
2. In AWS D1.1 - 2000 Table 4.5 titled as ' PQR Essential Variable Changes Requiring WPS Requalification for SMAW, SAW, GMAW, FCAW and GTAW. ', I want to resolve my ambiguity regarding following problems.  As mentioned in the table " A change in current in the amperage for each diameter used by : 10 %'" is an essential variable. " So, how is this variable applied if I have used a range of amperage current to fill the groove of the qualification test coupon ? For example, if, in the test coupon, I have used 170A for 1st pass, 200A for 2 nd pass and 150A for 3rd pass. Now, what amperage range may I mention in the WPS???
150 -+ 10% = 145 A / 165 A,  170 -+ 10% = 153 A / 187 A &  200-+10% = 180 A / 220 A
So, may I mention a current range in amperage as 145 A to 220 A for all the passes in the WPS? or should I mention like ' for 1st pass 145 A to 165 A; for 2nd pass 153 A to 187 A and for 3rd pass 180A to 220A?
Parent - By welderbrent (*****) Date 03-20-2017 21:36
Oh brother.
