Hi
I am not sure whether you could say that "AWS sees it this way or that way". Certainly, one could look at how a specific code classifies metal core. While I am not very clued up with many of the AWS codes, someone may be able to give you an answer if you stated the code specifically.
Just as a matter of interest, ASME IX considders GMAW, FCAW & Metal core to all belong to the GMAW process.
Niekie Jooste
No, you are interpreting CSA W47.1 correctly. MCAW is treated as a FCAW process, unlike AWS D1.1 which treats MCAW as a GMAW process. This has implications on the qualification of the welding procedures.
You are also right about your description of MCAW and the CSA's interpretation of MCAW. MCAW is a compromise between GMAW and FCAW. You get the penetration benefits of FCAW; however, you don't have a slag, instead you get a glass. This means you can reduce your labour costs.
