Up Topic Welding Industry / ASME Codes / Alloy 9310 welding repair?
- - By jjagg0125 Date 06-01-2017 17:17
i just recieved a call regarding a repair on a coupling welded in a 2" thick blind flange made of alloy 9310 the customer is telling us. after a quick search i cannot find anything on what P number this alloy would be. what p number is this and what grou is this? curious if one of our welding procedures will cover us or not.
Parent - - By jwright650 (*****) Date 06-01-2017 18:03
Are you sure that it isn't a AISI 4130 blind flange?
Parent - By 803056 (*****) Date 06-02-2017 00:45
This is posted to the ASME group, so I assume we are speaking of the ASME B&PC code. That being the case, ASME doesn't assign P numbers to AISI material specifications.
If you must comply to ASME, the answer is no because AISI material specifications do not list mechanical properties.
Parent - By dileepmarath Date 01-03-2018 04:46
Alloy 9310 is an unassigned(P#) material
