Up Topic Welding Industry / General Welding Discussion / ln-25
- - By jimwelds (**) Date 05-08-2003 22:13
Can an lincoln LN-25 spray 1/16" steel all day long, when it has a secondary contractor? If it can't is there a other one in a suit case style that will so this. thanks Jim
Parent - By supermechanic (**) Date 05-10-2003 23:16
I have found that the contactor can be 'jumpered' quite easily, the big issue here is 'will the gun take all of that heat'?
A water cooled gun may be the best here, as a 600 amp air cooled gun is about the same price, and it will get uncomfortably hot when using it. A water cooled gun will stay cool to the touch when using it at high amps/ high duty cycle.
