I have a question pertaining to maximum material thickness qualified per D1.3 .
I am qualifying a WPS for fillet welds using 18 and 10ga test plates and there seems to be some confusion over maximum thickness qualified.
The scope states that the code deals with material .188" or less in thickness. However in table 4.2 (PQR Essential Variables) section 10e states that "A qualification performed on 10 gage or thicker shall provide qualification for that WPS for sheet steel as thin as 16 gage and thicker, up to 2t thickness, where "t" is the thickness of the thinner sheet qualified."
So is the maximum thickness qualified .188" or .270"
Thank you for your time
