Basically, one can qualify a WPS with any parameters or conditions that may fall within the recommendations, or requirements of a code as well as any unusual on nonconforming parameters.
In one qualified a WPS for CJP groove welds without back gouging, than back gouging is not required for production welds. If the contractor qualifies a CJP groove weld without backing, i.e., open root, then production welds can be made without backing.
The contractor is free to do in production what ever was demonstrated by the qualification process.
A successful Qualification in the overhead position using E7028 permits the contractor to use E7028 in the overhead position.
Want to weld on oil soaked surfaces? Demonstrate it can be done successfully by qualifying the WPS with oil soaked base metal.
